Booster and another problems
After the last update, I noticed that some features on my website are not working, such as tagDiv Composer blocks, page loading, post templates have disappeared and do not open. I ran some tests by disabling the plugins and noticed that the tagDiv Composer plugin itself is causing this. I need help, as it is affecting the functioning of my website and part of the content cannot be accessed due to the following error:
wp_booster error:
td_api_base::mark_used_on_page : a component with the ID: single_template_2 is not set.
/home1/matine35/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_api.php
Blocks also do not appear on the home page and only display the code:
[td_block_16 m16_tl=”20″ category_id=”7772″ limit=”6″]
Other blocks and grids simply disappeared.
Here are two links to view the problems:
Home: https://matinecinetv.com.br/
Content: https://matinecinetv.com.br/2022/08/16/nosso-trabalho-e-unir-entretenimento-com-pertinencia-diz-raphael-montes-sobre-2o-temporada-de-bom-dia-veronica/
This kind of situation appears when, after the theme update, the theme plugins that have been previously installed are no longer installed/activated. In this case, the mentioned shortcodes are part of the tagDiv Standard Pack plugin, which can be installed from Newspape > plugins. After that, the problem will be resolved.
Thanks! Problem solved!
