I managed to change the category colours on the homepage with
custom css code:
.td-big-grid-post .td-post-category, .td-post-category{
background-color: rgba(127, 115, 115, 0.46);
BUT it does not change the box colours of the blog post category and tag colour.
Is there another custom code I can use?
Also, is it possible to change the background colour without it changing to the grid mode (instead of full width)
Thank you
Hello Punkey,
You should use the Inspector Browser to check the classes you want to apply your code, according to the following useful guide from here -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/ You should create it yourself because it’s custom-service and we cannot provide this kind of services, sorry!
