Box Header Using Header Template Default Pro
I managed to do this on an old site that is no longer available, bu struggling on a new site. I’m using the Cloud Library Template – Header Template – Default Pro. I’ve added a site background ad image but it’s being covered by the header section. I would like to confine the full header width to the same as the page size which is 1164px.
There is an option for the top menu row under extra to change Row Stretch to default which reduce the black tow at the top. I can#t find anywhere to do the same for the white background section containing the logo, header ad, menu and search bar. Whwn I check extra under the setting for that row, default is already selected.
We have some settings for the rows and different stretch sizes: https://www.screencast.com/t/bsbB5P97A
Make sure that this setting is disabled as here: https://app.screencast.com/FOwnXv63emAOR
You should access the theme panel settings, press save settings, and the to-top button will disappear from the header.
