Box hover layout problem
Dear support team,
I’m trying to create a layout in 1/6 with hover box it doesn’t work.
https://snag.gy/iLtMY5.jpg
It display full screen
Please see attached screen shot
I have made a gallery of 6 images below for you to see what I would like to achieve.
https://snag.gy/aCumOb.jpg
Hello Joophil,
You should disable the Td Composer if you want that function to be correctly rendered.
Thank you ! Fixed 😉
