box with an arrow inside
I’m trying to add a box with an arrow on the hero image on the top of the home page (under the header) how do i achieve that?
The hero element provides the option to set a title, a description, and 2 buttons (with icons), so if you want to create your own hero, here is how it can be done:
– drag a row and stretch it https://i.imgur.com/Qa4Y9Gg.png
– add an image and background color – https://i.imgur.com/vIpVvL3.png
– drag the element you need text, icons, buttons ….https://i.imgur.com/6XQg5y3.png
