Breadcrumb issue
When I first set up my site I had breadcrumbs following the category hierarchy i.e. Home > Parent Category > Child > Article Title
However now I have set up parent/child pages as the hierarchy and therefore would like this to be the breadcrumb structure instead : Home > Parent page > Child Page > Article Title
It seems that the latter breadcrumb structure is being followed if using the main menu navigation, however, it still shows the child categories I previously used
What is the quickest fix for this? i.e, breadcrumbs to follow the page hierarchy only and not include the categories?
I basically want the post pages breadcrumbs link to a page not categories
Maybe a plugin might work if you require a different breadcrumb implementation. Theme uses standard breadcrumb functionality. So you could disable the theme breadcrumbs and use a plugin to display the custom breadcrumbs. Maybe something like this if it works properly with the theme
– http://www.wpbeginner.com/plugins/how-to-display-breadcrumb-navigation-links-in-wordpress/
Thanks for the response,
Do you know where I can place the code? My attempts have failed so far
Thank you
Response above sorry
According to the instruction the code has to be entered in the header.php file of the theme
– https://www.screencast.com/t/5eYykSrk
Or try entering in the actual header template you use for the website, see how they display
– https://www.screencast.com/t/HMxlqGcIt
Enter the code below the existing code and check the results.
