Best to make a backup before adding various codes in the theme panel. The theme will store the custom code in the wp-options table->td_011 option name
– https://www.screencast.com/t/loBwXknCD
There you can search for these terms, depending on the section you entered the code in
tds_custom_html – https://www.screencast.com/t/8n6Z3XYLPpx
tds_custom_javascript – https://www.screencast.com/t/cmB4hN8x7xoJ
The custom code you entered should be seen there.
