Two things, Hope it’s fine for one thread.
1. I can’t find a way to get rid of the sidebar on all of the buddypress pages, like stream, account etc: You can register with FB/G+ and go to the Profile (link in the top bar) to see what I mean: http://www.portalexplora.com
2. Once logged in the login/register button changes to the name of the user (great!), however, why it doesn’t go to the profile page when I click on it? It’s a serious UX problem, as it’s intuitive to click on the username to get to your profile, for example the buddypress profile.
Thanks a lot
Seb
Hello Seb,
1)Unfortunately, the theme does not have any such an option that allows you to log in with social sharing, sorry! If is not what you mean, provide more details so I will be able to provide a more accurate response.
2)Provide some useful screens with the error so I will be able to provide a more accurate response and for a better understanding.
1) I didn’t ask how to create social sharing… I asked how to get rid of the sidebar on buddypress pages. In theory I should just choose to have fullwidth template (on the page settings) and it should work- but it doesn’t. And I said, that you can login (using fb or g+) and got to “profile” page to see what I mean. I already implemented social sharing đ
Screenshot-> https://imgur.com/a/qNNeo58
2) also I solved this one.
Seb
If you want to remove the sidebar for the bbPress template, notice that you can turn off this from Theme panel from here -> https://www.screencast.com/t/NF9tPZQbR
