Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins -> http://prntscr.com/pyewbu, also if you are using child theme, clear all cache and try again.
If there is still a problem, please provide some more details an a link where I can inspect this problem.
I have already made this attempt. The problem is not that it doesn’t work, everything works correctly but using the new BuddyPress display, going into the settings on the user profile unfortunately you don’t read the characters because they use a white background and the font color that I use, it’s too light for that background.
Hello I wanted to ask you even if you know how to recommend a plugin for the Buddypress image galleries. I had installed Rtmedia (plugin recommended by many) but the problem is that this plugin, in free version does not offer the possibility to adjust the max Kb for upload
If the problem with BuddyPress is on backend, then the only think that I can do is to suggest to change the WP Admin Color Scheme -> http://prntscr.com/pyw3z8
Unfortunately we can not recommend any gallery plugin for BuddyPress because we do not tested any of them.
I tried to make the change but the result does not change. I am attaching an image where the problem occurs. It would be enough for me to be able to change the font color in the white box to solve the problem
How can I attach a picture to you? I sent it to you by answering the email but I don’t know if it arrived
