Hello, my support has generally expired, but I want to inform you about a bug. When I publish a post starting with an iframe, the code is displayed on the home page and on the others. I’m also uploading a photo (https://imgur.com/a/jiBjXbz), I guess it can be shown from the first paragraph.
Hi lipcho,
Thank you for letting us know about this problem.
As a quick fix what you can do is to set for those posts that use iframe an excerpt -> https://i.imgur.com/4NRo4ua.png this should fix the problem.
