BUG? Smartlist issue with using captions on images
When we use a caption on an image with a smartlist, the description of the smart list element disappears. When we remove the caption on the image, the descriptions appear for each element.
Have you guys seen that? Anyway to fix?
Hello schindyguy,
Please notice that the Description appears only for images which are set to the Attachment page, otherwise, this element will not appear and therefore, the description will never appear nor in smart list. For more information about this case, please refer to this topic here -> https://mor10.com/power-of-wordpress-image-metadata/
If you refer to something else, please provide some useful screenshots and provide more details about your problem so I will be able to provide a more accurate response.
Hello Catalin!
So I don’t mean the meta description of the image attachment. I mean the actual written text that comes after the image on a smarlist
Check http://screencast.com/t/yJY2oK61IqD
If you attempt to add a caption for the image (going into media attachement, adding a caption), the description of the list element disappears.
I believe the bug is reproducable on your demo. Just go into this post http://screencast.com/t/yJY2oK61IqD , for the image of Emanuela De Paula, click edit on the visual editor, add in anything in the caption area
http://screencast.com/t/FapbqpXW1X
now save the post/publish and you will see that the description of that list element that used to be there “Too much work. Let’s burn it…” is gone
I’ve checked this on my end but couldn’t duplicate the issue. As can be seen her the text is displayed fine even if I add a description for the image: http://screencast.com/t/pVQA04pDQR – http://screencast.com/t/yCDirF6yEi7 Please provide a link where we can inspect this issue and we will get back to you as soon as possible. Also provide smart-list’s content from editor mode via http://pastebin.com/
Hi Andrei, I didn’t want to post site info in this forum so I emailed the details to contact@tagdiv.com with attention to Catalin, please let me know via email! THANKS!!!!
