I understand that the Newspaper theme doesn’t support sticky posts.
This is a functionality that I need however, so I’m looking to build it myself.
I would want the sticky post to appear at the third position of this loop:
Where do I find the code for this loop?
Hello !
Depending the blocks you use you can find the codes in here: https://www.screencast.com/t/Gq5gkPMXSF7
