Bulk Update Post Templates for specific posts without affecting global settings
We’ve imported a large database of content to the new site, within various categories. For various reasons, we need to set a specific post template for all of these older posts; and will maintain a different template for all new posts based upon the global settings in Categories.
Knowing full well, we can edit specific post templates within each post; we have over 2000 posts that will need one specific template that isn’t the global category. Is there a way to bulk change just these posts – or can other users suggest a plugin that they have found that may work (understanding the devs can’t guarantee success at all).
Any suggestions would be value.
Thanks,
Jason
Hello Jason,
Unfortunately plugins cannot work like that as plugins are created for wordpress. Our post templates are custom so I doubt any plugin can tie itself into our code. Unless it;s created specifically for it.
Unfortunately the theme has no setting like the one you require, but you can reset all of your posts to a specific template by adding all of the old posts to a specific category and then using this method to set a specific post template to it: https://forum.tagdiv.com/topic/different-post-template-for-one-category/
Hope this helps.
