business directory module not working with newspaper mobile module
I’ve attached a business directory to my site http://www.ellenbrooktimes.com.au and it works fine under the main theme, but using the mobile module, the directory doesn’t show up. I’m sure it’s a simple fix but I can’t find it. 🙁
  • This topic was modified 3 years by tommy_n.
It seems you have the mobile theme + amp activated.
Please deactivate those plugins, tagdiv mobile theme and amp, clear all cache.
The mobile theme comes with its own templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout, the page content is made without builders in mobile editor => https://www.screencast.com/t/xbgZG8kH also, the options that are provided to edit the mobile theme version are limited (this keeps the things simple)).
So, if you want to use the cloud templates, then you need to disable the mobile theme and AMP plugins, and then use the responsive version.
You can disable the mobile theme plugin on the pages from the Gutenberg editor using the following option => https://www.screencast.com/t/axXRJsWby
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ -> https://forum.tagdiv.com/topic/amp-pages-not-working-well-with-this-theme/ and choose what mobile version you want.
