Button for showing Instagram section does not work properly
Newspaper V 10.3.6.1
Wordpress V 5.5.1
Newspaper Theme Panel / Footer / Instagram settings
“SHOW THE FOOTER INSTAGRAM SECTION
Show or hide the Instagram section”
– Turn ON/OFF button just affects this text to show or not to show:
“FOLLOW US ON INSTAGRAM @
Instagram GalleryBlock Render failed – no data received, please check the Instagram ID connect to your Instagram Account.”
– It does nothing with space on website footer, reserved for pictures from Instagram.
There is a lot of empty space with a small broken picture icons (6 of them).
I just want to remove whole Instagram section, because I don’t need it. How to do that?
Thank You,
I love the theme.
PS.
Newspaper Theme Panel / Social Networks
– Here I didn’t change a thing (there is no connected Instagram account).
  • This topic was modified 6 years by srnos.
A link to the website would have been very helpful.
Maybe the Instagram section is not coming from the theme panel footer setting. Are you using a cloud footer template?
Please edit for example the homepage with the composer, scroll down and see if you can remove the Instagram section from the footer.
Cloud footer templates have to be edited in the composer, only from there you can add/remove/customize footer elements from the template.
Let me know.
