Buttons with sound?
Hi people. I’ve been trying to add some buttons with a sound effect to my web, but I cannot find the inside the tagdiv editor or the block editor. I want the process to be an easy one, as I plan to repeat it in a kind of sound catalog. I can create buttons and add a URL, even with autoplay function, but just get the sound when you click the button is an option apparently not available in known plugins, the tagdiv editor.
Any help?
Hi ludwigrittersp,
I’m sorry, but our theme do not have this option.
To add sound on buttons you’ll need some custom code or some extra plugin, unfortunately I do not know to recommend one that will work.
