buysellads help placing code
Hi there, I am about to change from Thesis, to Newspaper 6. I run BuySellAds on my site (in the sidebar) BuySellAds give me two code snippets. One to put in where the advert will appear, but another that has to appear on every page at the very top of the <body>
Could anyone help me by explaining exactly how to place this code when I switch themes? I do have some very basic coding knowledge and FTP access but am not an expert, so it needs to be a ‘for dummies’ explanation. 🙂
Many thanks for your help, Pippa
You will have to add your code in header.php where the body tag is – http://screencast.com/t/ukcovv7i8h and the other code where the advert will appear. The theme ad system was designed for adsense code but you can also try to add it in Theme Panel > Ads section – http://screencast.com/t/IckVfivoLW depending where you want to display it, please also check documentation – https://forum.tagdiv.com/header-ad/ For pages you can use Ad box block to display your advert in the content – http://screencast.com/t/EMPFNvzf
Hope this helps!
OK, thanks, I did not realise that the body tag was in the header file. 🙂
