The problem is on the website http://www.ilprimatonazionale.it.
If you try to open the site in incognito mode (google chrome) you will see the mobile version.
If the mobile version was deliver on desktop, then this problem was from the cache plugin that you are using, this do not know when to deliver the mobile cache version and when to deliver the desktop cache version. Usually, we recommend to use cache plugins with support for mobile cache. Please check the settings from the cache plugin that you are using.
Let me know the results!
