Caching Problem
How come when I go to my website I don’t always see the most recent posts. It is like the website is cached. Why is this? I never had a problem with this before the newspaper theme. How do I disable the newspaper caching or fix this issue?
This is what my hosting platform said: In some cases themes can have a caching layer that used for static CSS files. Typically this can cause a conflict with the server side cache not properly purging the most recent changes since a second layer exists. Plugins can have the same effect. The newspaper theme has a CSS generator setting that appears to be the same thing just using a different naming convention. You can check with the theme provider to see if there any options to have that feature work alongside the serverside cache or if it would have any adverse effects turning off the feature.
Does this problem also occur when you are logged in? The theme doesn’t have cache except for the flex blocks, but it’s different from regular caching and only applies when pagination is used. Could you please tell us which caching plugin you are using?
Yes, the problem also occurs when I am logged in.
Nginx Helper. DreamHost says that isn’t the issue though. That plugin is used to communicate with the DreamPress server side cache to clear/purge cache from wp-admin.
I would like to take a look. Can you please contact us via email at contact@tagdiv.com and provide the wp-admin access? Include the link to the topic in the email.
