Cali Sight Theme – search engine based on any detail
I would like to know how to give to the search engine the function to be able to find results based on any detail of the listing, such as: location, name of the activity or any taxonomy option etc.
thank you for your precious help
Cheers
Mar
Hello Mar!
You will need an SEO plugin for that.
Hi Bettina, thanks for your reply.
Is strange I should need a plugin because whe I’ve tried the demo version of the EasyCoast Check, the search engine was finding any of the words (location, attribute etc). Also on the demo version od Doctor Pro there’s this function. But on Cali Sight is not?
Thanks for your help
waiting for yours
Mar
Hello Mar!
I see that this demo was not set up here: https://app.screencast.com/Nd4yp1hJs6K4u
You should edit the modal, click on this element, and set your taxonomies.
Hello Bettina,
I don’t have in Cali the same layout you shown in the picture. If I click on the lens icon to modify modal search it appears other type of set up.
I Tried to add a new search form in the middle of the page but I dont have the settings you have in the picture. They are very useful to what I want bu I cannot find the way to get it
Thanks πŸ™‚
Cheers
Mar
I’ve Found it. but the layout is totally different. It doesn’t take the style of the theme: space to write text and buttons are squared and with no style.
I’ll do my best to keep it similar.
Thank you for your precious help πŸ™‚
Cheers
Mar
Hello Mar!
You should edit the modal page. The short way to do this is to access the homepage, click on the modal, and edit it from here: https://app.screencast.com/0wWQffEtbmysY
Thank you Bettina.
I cannot have the EDIT option when access to the home page like your example.
Is there another way to add elements to the list?
Than you!
Mar
Hello Mar!
If you use the latest update of the theme and plugins, you should have access. Please note that only when you hover can you see it.
Every modal has a page that can be found in Dashboard -> Pages. Edit it with the TagDiv Composer.
Hi Bettina, Thanks for your reply.
I’ve it updated but the option doesn’t appear unfortunatly.
Also, I’ve created 2 listing forms bu the terms I’m searching now appears only about the first form, not the second. For example names, specialities, etc of the second one doesn’t appears on search results.
Thanks for your help πŸ™‚
Mar
Hello Mar!
Can you please provide more information about your issues and the settings you’ve applied?
Hi Bettina,
I’ve found the issue.
I add the CPT on the results of the custom search πŸ™‚
It was easy πŸ˜‰
Thanks for your excelent support! πŸ™‚
cheers
Mar
  • This reply was modified 2 years by Mar.
I’ve found all the issues solved.
Thanks one more time Bettina! πŸ™‚
Cheers
