Can anyone help with Custom Taxonomy Mobile Templates issues ?
I can’t get the Cloud Mobile Templates to be shown on Custom Taxonomies for Custom Post type.
The Custom post type Mobile template it’s been displayed as expected.
i am not using Mobile theme. Below screenshots that will help you to understand the issue.
Cloud templates -> CPT/Taxonomies https://ibb.co/r37D0YJ
Custom Taxonomies – Templates (Jobs-Archive Mobile Template Design) -> https://ibb.co/zRNVpny
Taxonomy shown in front-end -> https://ibb.co/DbcLrBJ
Plugins list -> https://ibb.co/X3MBhdH
So basically it seems that the mobile template is not been applied in the taxonomy. The “desktop” template has been applied correctly. As well all templates under Custom Post Type – Templates are shown correctly both Desktop and Mobile.
Can anyone help me ?
This problem seems to be delicate, can you please contact us via email at contact@tagdiv.com, and we’ll investigate the problem there. Also, please provide a temporary wp-admin access – https://www.wpbeginner.com/plugins/how-to-create-temporary-login-for-wordpress-no-passwords/
Hello Calin,
I have already emailed you at contact@tagdiv.com but I haven’t received any support.
Can you please help me with this one as it’s urgent for my business?
Can you find the email chain or I should resend?
Thank you?
Hello @mariospavlou!
I’ve already replied to you via email.
Please do not create the same topic in multiple locations in order to avoid multiple responses!
Thank you so much for understanding!
Hello Bettina,
Ok, looking forward for a quick solution for this theme’s issue.
Marios
The above issue has been fixed in the latest update (Version 12.6.3 )?
Marios
So can anyone reply to the above please?
Here you can see what we fixed already in the Newspaper updates: https://tagdiv.com/newspaper/
So the above has not been fixed yet!
Did you put a note in your bugs list?
Yes.
