This is what it looks like when try to insert pricing table shortcode inside a post:
https://spurt.no/wp-content/uploads/2019/07/pricing-table.jpg
Not good at all!
I can’t make a new template in the cloud because it is far too cumbersome with sidebars and anything else that should be similar to how posts look like. This is frustrating!
Why is it not an easy way to insert shortcodes inside posts? This you really have to do something about!
This topic was modified 7 years by
spurt.
Is possible that you have some inline css on the shortcode that set, and this css set the width 100% on the page, please provide me a link where I can inspect this problem, in this way I will be able to provide you wan working answer.
Here is the code I have inserted:
[tdc_zone type=”tdc_content”][vc_row][vc_column][tdm_block_column_title title_text=”Rm9ybiVDMyVCOHlkaGV0c2dhcmFudGk=” title_tag=”h2″ title_size=”tdm-title-md”][/vc_column][/vc_row][vc_row][vc_column][tdm_block_inline_text description=”VmklMjBpJTIwU3B1cnQlMjB2aWwlMjBhdCUyMGR1JTIwc2thbCUyMHYlQzMlQTZyZSUyMDEwMCUyNSUyMGZvcm4lQzMlQjh5ZC4lMjBEZXJmb3IlMjBnaXIlMjB2aSUyMGRlZyUyMGVuJTIwMzAlMjBkYWdlcnMlMjBnYXJhbnRpJTIwcCVDMyVBNSUyMHByb2R1a3RlbmUlMjB2JUMzJUE1cmUuJTIwRXIlMjBkdSUyMGlra2UlMjBmb3JuJUMzJUI4eWQlMkMlMjBmJUMzJUE1ciUyMGR1JTIwcGVuZ2VuZSUyMHRpbGJha2UlMjBpbm5lbiUyMDMwJTIwZGFnZXIlMjBldHRlciUyMGF0JTIwZHUlMjBraiVDMyVCOHB0ZSUyMHByb2R1a3RldC4lMjA=” display_inline=”yes”][/vc_column][/vc_row][vc_row][vc_column width="1/3"][tdm_block_pricing title_text=”MTAlMjBrbSUyMGZvciUyMG55YmVneW5uZXJl” title_tag=”h3″ title_size=”tdm-title-sm” description=”MTAlMjBrbSUyMHRyZW5pbmdzcHJvZ3JhbSUyMHRpbHBhc3NldCUyMG55YmVneW5uZXJl” features=”OCUyMHVrZXJzJTIwdHJlbmluZ3Nwcm9ncmFtJTBBRmxla3NpYmVsdCUyMG9nJTIwZW5rZWx0JTIwJUMzJUE1JTIwdGlscGFzc2UlMEFUaWxwYXNzZXQlMjBueWJlZ3lubmVyZQ==” features_tdicon=”tdc-font-fa tdc-font-fa-check” features_non_tdicon=”tdc-font-fa tdc-font-fa-remove-close-times” button_text=”Kjøp” button_tdicon=”tdc-font-fa tdc-font-fa-shopping-cart” button_size=”tdm-btn-md” content_align_horizontal=”content-horiz-center” initial_price=”0″ currency=”Kr”][/vc_column][vc_column width="1/3"][tdm_block_pricing title_text=”MTAlMjBrbSUyMGZvciUyMHZpZGVyZWtvbW1lbmRl” title_tag=”h3″ title_size=”tdm-title-sm” new_price=”99″ currency=”Kr” ribbon_text=”-50%” description=”MTAlMjBrbSUyMHRyZW5pbmdzcHJvZ3JhbSUyMGZvciUyMHZpZGVyZWtvbW1lbmRlLiUyMA==” features=”MTIlMjB1a2VycyUyMHRyZW5pbmdzcHJvZ3JhbSUwQUZsZWtzaWJlbHQlMjBvZyUyMGVua2VsdCUyMCVDMyVBNSUyMHRpbHBhc3NlJTBBTSVDMyVBNWxiYXNlcnQ=” features_tdicon=”tdc-font-fa tdc-font-fa-check” features_non_tdicon=”tdc-font-fa tdc-font-fa-remove-close-times” button_text=”Kjøp” button_tdicon=”tdc-font-fa tdc-font-fa-shopping-cart” button_size=”tdm-btn-md” content_align_horizontal=”content-horiz-center” initial_price=”199″][/vc_column][vc_column width="1/3"][tdm_block_pricing title_text=”UGVyc29ubGlnJTIwdHJlbmVyJTIwMTAlMjBrbQ==” title_tag=”h3″ title_size=”tdm-title-sm” currency=”Kr” description=”MTAlMjBrbSUyMHRyZW5pbmdzcHJvZ3JhbSUyMG1lZCUyMG9wcGYlQzMlQjhsZ2luZyUyMGF2JTIwcGVyc29ubGlnJTIwdHJlbmVy” features=”MTYlMjB1a2VycyUyMHRyZW5pbmdzcHJvZ3JhbSUwQVBlcnNvbmxpZyUyMHRyZW5lciUwQVRpbHBhc3NldCUyMG0lQzMlQTVsJTJDJTIwZm9ybW5pdiVDMyVBNSUyMG9nJTIwYWxkZXI=” features_tdicon=”tdc-font-fa tdc-font-fa-check” features_non_tdicon=”tdc-font-fa tdc-font-fa-remove-close-times” button_text=”Kjøp” button_tdicon=”tdc-font-fa tdc-font-fa-shopping-cart” button_size=”tdm-btn-md” content_align_horizontal=”content-horiz-center” initial_price=”990″][/vc_column][/vc_row][/tdc_zone]
The tagDiv Composer is a builder made for pages and templates not for post, from what I can see you set in post content/section shortcodes from tagDiv Composer, those will not work property in this way.
If you want to set some shortcodes in some posts, you can use the shortcode element from the Gutenberg editor -> http://prntscr.com/oi9efi
