I’ve created a user submit using gravity forms. Users are default set to Contributor when they sign up. The post appears in their ‘Posts’ section. Is there anyway to allow them to edit their posts from the front end?
Users such as authors can create and post content in the website, default WordPress allows it. The theme will not interfere with the default user roles or alter them. Users can access the dashboard according to their role capabilities.
Roles and Capabilities -> https://codex.wordpress.org/Roles_and_Capabilities
The theme doesn’t add more features in this matter. The theme login will also be the default WordPress in core, the modal login window was implemented for a nicer interface.
