Can you call related post using custom taxonomy?
I am using PODS(plugin) for creating custom taxonomy.
While using the ‘Single Related Post’ element on a cloud template, can we call the posts on basis of custom taxonomy?
The TagDiv composer under General>Extra gives option to call “Related Post Type” by Categories and Tags. Can custom taxonomy be automatically added to that dropdown?
I think that you are referring to this https://i.imgur.com/iwIvxGl.png I’m not sure, maybe it can work if you edit the files of that element -> wp-content/plugins/td-cloud-library/shortcodes/single/tdb_single_related.php. But, please try something different, what you should do is to use a flex block and in filter tab set https://prnt.sc/2410idq but this also has an inconvenience, will not select the taxonomy after the current post.
For the moment those are the only solutions that I have in my mind.
Hmm. Thanks.
I understand what you are saying. But doesn’t quite solve the problem.
If I have an article about “violin” and another one about “mango”. There isn’t a way by which I can show other articles related to “musical instruments” and “fruits” respectively on their pages. [Musical Instruments and Fruits are taxonomies]
Hope you get what I am trying to achieve.
Can you consider this for your future releases? Clubbing “custom taxonomy” in the same dropdown of categories and tags of related articles will be very helpful.
Hello @sudipto!
We will take in consideration your query.
Thank you for understanding!
