I’ve spent a couple of hours trying to find this. It was easier in Newspaper 7 to set the “Load More” posts button for the homepage, but for the life of me, I can’t find it in Newspaper 9. I understand that I can style the block using TagDiv Composer, but cannot figure out how to activate that on the home page.
How do I access TagDiv on the index.php page?
It’s a very simple home page with blog posts listed up to 5, and then a “load more” button.
Please help.
Thanks,
Bob
This topic was modified 7 years by
bobfine.
Please make sure you also update the tagdiv composer page builder by accessing the plugins section and pressing the update button for it.
Also please disable all non theme plugins as we have seen plugins disable the composer button in the past and it could be the case now.
In order to set the load more is very simple using the tagdiv composer. Simply select the block and activate the setting here: https://www.screencast.com/t/KwEY2sSJBN4
Bogdan,
Hi. Appreciate the reply. The plugin is up-to-date. This is a clean install. The composer plugin is up-to-date. I deactivate all the plugins except composer, and still get can get access to it.
Do you want to login to the site and take a look, or at least activate the “load more” setting?
Thanks,
Bob
OK,
Please contact us via email at contact@tagdiv.com so we can login and investigate why this happens.
