I’m using a cloud template (Gossip) and I tried everything you said here > https://forum.tagdiv.com/set-block-inside-post-content/ but nothing happens inside my post content.
I’ve created a page and added a flex block, then I copied the code
[tdc_zone type=”tdc_content”][vc_row][vc_column][td_block_trending_now][/vc_column][/vc_row][/tdc_zone][tdc_zone type=”tdc_content”][vc_row][vc_column][td_block_trending_now][/vc_column][/vc_row][/tdc_zone]
And pasted inside the single post template, on Content block as an inLine Ad:
Not even adding in the Theme Panel… (I dont use any other kind of ads)
Am I doing something wrong?
You need to add only the code foe block, without the row/column -> https://i.imgur.com/0CGegB6.pnghttps://forum.tagdiv.com/set-block-inside-post-content/
Still doesn’t work…. nothing happens….
It should appear after 1st paragraph.
https://imgur.com/a/EZ8pbnQ
So, please delete the code from Theme Panel, because that option is for standard templates.
You need to check this guide to add them after x paragraphs -> https://forum.tagdiv.com/article-ads/ and add it in one section save and check in the frontend, not in the composer editor.
