Can't exclude specific posts when using Post Loop element
Hey tagDiv team, how are you all doing? hope everything is okay!
I’m trying to exclude some specific posts using the ID when inside my Post Loop element and it’s just not working as expected as you can see on the screenshots:
Here is my usual post loop element without any excluding id:
https://prnt.sc/20t3t2c
Now I’m trying to exclude one specific post from the list:
https://prnt.sc/20t44ho
So as you can see it’s working as if the option was not “exclude” but “include” after all the only remaining post was the one that was supposed to be excluded from the list…
Can you help me with that?
Thanks and take care!
We’re fine, thanks.
Please check this screenshot: https://www.screencast.com/t/0RpqW2ENjTB2
