Can't get blocks to output in more than 1 column. How do I do a 3 column block?
I’m trying to use Block 14 in a row or inner row to output a 3 post 3 column layout.
Like this:
https://demo.tagdiv.com/newspaper/block-14/
I can only get it to output in a single column and all the modules are stretched to 100% width of the row width and stacked. I’m actually getting the issue with other blocks too.
When I compare the code output I’m getting vs the demo site I see the row is getting assigned different classes:
td-column-3 vs td-column-1
What do I need to need to do to make this work? Feels like either something isn’t working right or I’m missing something obvious.
More info:
It works if block inserted into a 1 column row.
Will not work in a multi column row (such as a sidebar left with main content & block on right)or as a single column inner row.
The layout is made in this demo =>https://www.screencast.com/t/mHqVuaOv9 because the row layout was divided into 2/3 + 1/3, where block 14 was added.
So if you want to have a block 14 where it should be divided into 3 columns, then the row layout should be 1/1, I made a video that can help you https://we.tl/t-CIeTSqBU74
If this is not what you mean, please provide more information.
I understand that’s how it should work, but my problem is that it is not doing that. It looks fine in the tagdiv composer view, but then after saving & viewing it goes to a full width stacked layout.
I can send you video of the issue.
This page was created with tagDiv composer or did you use another page builder?
Also, if you use the WPBakery for pages, we strongly recommend using only one of those plugins with our theme (WP Bakery or tagDiv Cloud Library, but not both).
Also, make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Using TagDiv Composer.
Try what you did in the video, but make sure you save it and then view the front end of it. I can get it to look that way in the tagdiv composer, but the front end is messed up.
Cache cleared.
I’ve tried deactivating just about all of the plugins.
Switched to the parent newspaper theme.
Created New Page and tested it in different row configurations. The only one it will work in is a single column row.
I also tried this on a completely different newspaper site and got the exact same result. Block 14 will not in a multi-column layout.
Update: The 1/3 + 2/3 Layout is the only multi column layout that works with Block 14.
All others I’ve tried just show a full width stack.
Can you send me screenshots or a step-by-step video and how is it displayed, please?
It will be much easier for me to understand exactly what is the problem.
Create Row 1/4 + 3/4
Insert Block 14 in 3/4 column
Save
View
Here’s a video.
http://somup.com/crfUQQFUB7
So, maybe I wasn’t clear enough in the explanations, the layout on the first line of the row applies to elements called blocks, the other layouts including the first line apply to flex block elements.
So you can use for blocks from Standard Pack the layouts => 1/1, 2/3+1/3, 1/3+2/3 and 1/3+1/3+1/3
