Can't remove custom body class
please help!
I add custom body class code thrue theme panel and every page that I enter has this error: wpb-js-composer js-comp-ver-4.11 vc_responsive td-animation-stack-type0 td-boxed-layout td-ad-background-link” itemscope=”itemscope” itemtype=”http://schema.org/WebPage”>
http://www.uesmag.com/
Where can I remove custom body class code?
If you added a custom body class in the theme panel, I think the answer is pretty straight forward. Exactly where you added it. This is where our theme lets you add a custom body class: http://screencast.com/t/XVe8hCboD9Bh
Simply empty this filed and the custom class should disappear.
