I did a theme upgrade from version 9.x to the latest version. I know there were several major versions I upgrades at once, but I took a chance… After the upgrade I can´t view the start page properly https://www.roslagsbanan2.se/ or the posts http://www.roslagsbanan2.se/hyra-ut-i-andra-hand/, but the pages look OK https://www.roslagsbanan2.se/for-maklare/.
I have updated and activated TagDiv Composer and Cloud Libary. I assume I need to something with the post templates, but what? I have tried to update a post, but it did not help.
About the start page; I made it so long time ago that it can be made in Visual Composer (or whatever the name was). I am tempted to try to open it in TagDiv Composer and save it from there, but I decided to ask for advice here first. (I know it is said that the start page needs to be created again from scratch changing from Visual Composer to Tag Dig Composer, but I have previously successfully just opened and saved another start page in TagDiv Composer).
I am not a developer, I can do configurations within the theme, but no coding or too technical suggestions.
Problem solved; I installed and activated the Standard Pack plugin. Wanted to delete the question, but couldn´t find how to do it.
It is not recommended to save a page with tagDiv Composer, a page that was made with a visual composer, because it can appear errors.
Please note that the WP Bakery has a conflict with the tagDiv Composer. Please use only one builder and not both. So, I gladly recommend you to shift from WPBakery to Composer, because WPBakery is an old builder plugin. Please check our guide to know how to shift from WPBakery to Composer: https://www.screencast.com/t/6xLVMmlsY ; https://www.screencast.com/t/zWHrRmK1LQC ; https://www.screencast.com/t/vuFdT9Stx ; https://www.screencast.com/t/DWbSf3qj ; https://www.screencast.com/t/QuHyGccTK71v
