carousel block problem
what i have to do to my carousel block work? to look like here https://forum.tagdiv.com/modules-and-blocks/(gallery), i put block and click to show my post and its look terrible.
You have to customize it to look good for you. Make sure you go trough all it’s settings and adjust it to look good. You can also add and use a custom css class if you need it to style it some more, like I did here: http://screencast.com/t/auY537xS8
Unfortunately in the last version of Visual Composer we also lost some of the classes as they have changed and some Visual Composer elements lost their css, we have this on our todo list and we are working on it unfortunately we still have incompatibility issues regarding VC style.
Thanks for understanding!
i try like you every time, but nothing, it’s not good, it’s not work… i will try with custom css class like you and i will see…
i have some other problems, i will contact you after i finish this problem (like social counter, my header.. )
thanks for your support
have a nice time
You could try to find and use a plugin to achieve that. Hope you manage to do it via custom css. Please let me know about the other issue you have.
I try everything as you say but nothing… is anything else that i can try
Unfortunately I don’t think that there is something else as this still needs to be styled, as I suggested before you could try to find a plugin for that dose that and hopefully we will managed to fix this soon.
Sorry for the inconvenience!
ohh
can you suggest me a good plugin for carousel which will work fine with newspaper… i lost carousel and width website, i still haven’t finish my site 🙁
will it be a problem connect a newsmag and newspaper? because in new theme there is a perfect width and good block for gallery and video, in newspaper i wanted to that with carousel…
Unoftunatelly I can’t recommend and guarantte you a plugin that will work with newspaper as we haven’t made any teste with any plsuing of this kind. You should try something like Carousel Horizontal Posts Content Slider for ex or similar. Test it and see how it behaves and if it doesn’t work well, try another.
Sorry I can’t can’t give you an exact answer on this but I guess you can understand that we cannot test all plugins available out there.
Not sure what you mean by connecting. If you mean if you can use them both or something like that, you can do it, switching to newsmag should be as easy as switching to another theme.
Hope this helps!
I mean, is it difficult to switch to the Newspaper on NewsMag … should I start over again adjusted, from SEO, security, blocks …?
I think I get the NewsMag but then i lost $ 60 and 4 months of my time :(, but again, NewsMag have things what i need …
is there something that newspaper has a NewsMag no … whether it supports tiled gallery?
Shouldn’t be difficult as it’s the same platform and you can make the same changes and more regarding the fact that newsmag has more features and since you already done this changes should be easy for you now.
Newspaper dons’t have any features that newsmag doesn’t have and newsmag also support tiled galleries.
