Carousel problem with internet explorer
I use carousel with internet explorer, images show up at the right side of the screen instead of center. With other browsers it works perfectly fine but with internet explorer it is not. How can I fix this problem?
Thanks for support
hi,
the carousel is a component of the jetPack plugin, is not from our theme.
try to update the jetPAck plugin to the latest version, maybe they solved this problem.
Thanks for you message.
Radu A.
