Hello, I am trying to setup the theme and I just did small changes to the Case studies – now they are Projects instead. I have changed everything needed and its working correctly except the thumbnails on the home page.
^^ This is how I see it and on the demo its totaly different than what I have, did I mess something ?
Hello @sotirow96!
There are some flex block builders using the Module Template: Case Studies. You can also edit the module template. Documentation is here: https://forum.tagdiv.com/modules-builder-newspaper-theme/.
