Categories Display Same Posts
Whrn I click on different categories on my blog , the same posts are displayed. What might be the problem?
Hello !
Please provide a link to your website.
Mwabaya.com
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
PLEASE NOTE THAT DUE TO THE HIGH SUPPORT REQUEST THE RESPONSE MAY GET DELAYED UP TO 48H !
I’m having this problem too, what’s the solution?
https://prnt.sc/14xbgoe
https://prnt.sc/14xbpg0
I have 5 different categories. When I change a category from the category filter, all categories change. For example: when I filter the category “a” to “a”, category “a” posts appear on the page of category “b”.
thx
  • This reply was modified 5 years by Emre.
Have you checked for a plugin conflict? You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Also, in your screenshots, you have the same category set in the category filter.
To display the posts from the same category, please select Single- Related by category => https://www.screencast.com/t/A4t8zVEaFsA
