Every time I try to fix this, it won’t fix. I want my category pages to show the articles for that category- I use the current category. It will NOT pull the articles from that category- It pulls ONLY from the first category on the navigation menu. REALLY getting old how many bugs this thing has,
For the category template, please use posts loop; if you have set a posts loop then will display all posts in this category or you can use Flex Block/Big Grid Flex and set the filter to “Category -Current category” => https://i.imgur.com/7P99qx0.png and this is why the block will display posts for each category. So, please check the settings.
i need more direction than this. I did what you said and it won’t work. Where is the categories template/
