Hello Snaru,
If you want to hide this feature, please try the code below and add it in Theme panel->Cusotm CSS area.
The code is ->
.td-pulldown-filter-display-option{
display:none;
If is not what you mean, please provide more details about your desired changes so I will be able to provide a more accurate response.
Thank you for the message!
Hello Snaru,
Please try to disable all the active plugins, leave just Visual Composer, clear all cache and install only the plugins that come bundled with our theme and check it again. If your problem is still there after this changes, please let us know.
Hope this helps!
Hello Snaru,
I do not think that the problem comes from the SEO Yoast because this kind of plugin is tested with our theme and works as expected. I suspect that your problem comes from your untested plugins that could cause some interference between SEO Yoast and our theme and can produce some errors. We recommend using only the plugins that come bundled with our theme and also our tested plugins -> http://screencast.com/t/kRc7zojb3HR
Hope this helps!
Unfortunately we have no reports of speedbooster interfering with any theme option. Please make sure you use the latest version of the theme and disable all plugins except visual composer. This is how you check a plugin for compatibility. You activate it and check the infinite load again. If it works, then deactivate it and activate the next one and so on and so forth. Please test this again and check it only with visual composer and speedbooster and if this is the case in which the infinite load is not working, please send us an email at contact@tagdiv.com and provide wp-admin so we can take a look. Also include a link to this topic.
