Category and post visibility problem.
I installed the Newspaper theme and uploaded the Corona template as an example. On the homepage, in the blocks section, I noticed that even though I select certain categories, different category names appear instead of the ones I chose. Also, newly added posts aren’t appearing in the selected sections. What could be the reason for this?
1 : https://ibb.co/G2DCJ8w
2 : https://ibb.co/s3pJFBK
3 : https://ibb.co/zHWW36q
please help me 🙂
If you select a category as a filter and a post is assigned to that category, it should appear. If the post does not appear, there could be an offset set. Let the offset field be empty with no space or value, and see the results: https://prnt.sc/26SoUFv7QzxG -> https://www.screencast.com/t/peVbVmUDE.
If your articles have more than 1 category and the first category is displayed there.
A solution there could be to set a primary category for each article. To do this, you should edit the post normally and set the category you want displayed: https://www.screencast.com/t/W3DlctW1 ; then, the article will have the category you need there. Please note that this article will always appear with the primary category. (for 2 categories, for example)
