Category Article Display View
In the display view for the categories, there are two empty blocks after the 10th article. It looks like indicated below.
Article | Article | Article
Article | |
Article | |
Where can I set the number to 12 so it fills the rows properly? Or is there another way to fix it?
Lana
If you want to increase that limitation you will need to do it from Theme panel from here -> https://www.screencast.com/t/GtRphbxEAKf Please note that your posts number to show must be divisible by the number of columns.
Thank you so much!
