Hey guys,
I encountered a small problem and I can’t locate the issue. No matter what background I apply to the theme, that background works ONLY on the homepage, the category pages (and any post page) override it, even if I set a specific background to that category.
Let’s say I’ve added a red background to the category X, once I visit that category page, the background is red but it changes immediately after 1 second.
Any help is appreciated.
I did set a background picture from Customize but I thought that should apply site wide not only the homepage. Here’s the link: http://www.gamesmatic.com/category/reviews/
Tnx alot
I have the grey background set as a general background and for the category Reviews for example, I have the red background (added as test). As you can see, once you visit Reviews, it will turn red then immediately grey. And if you look closer on the background of “reviews”, it’s a different background altogether than the main background.
It’s strange and I can’t localize the issue.
What i see and is strange for me…why do you have that category there: http://screencast.com/t/s81o9BrC6
Please can you send me access to your wordpress to take a look.
Send via email at contact@tagdiv.com
may I ask how you’ve added the shadow behind the big slide module (http://www.gamesmatic.com/)? Looks nice!
Greetings
davistar.
It’s easy, you just look for the parent div of the slider and you add the following css:
-webkit-box-shadow: 0 0 35px rgba(0, 0, 0, 0.5);
-moz-box-shadow: 0 0 35px rgba(0, 0, 0, 0.5);
Evidently, you can tweak that for your liking…colors, thickness etc
