category filter in flex block 1 not loading posts from category?
as per the title, i have a category filter in flex block 1 not loading posts from category.
i have the category “https://staging.nannyoptions.ie/category/parenting-guide/parents/breastfeeding/” in the category filter in the elements section, but it will not load any post for some reason?
is this down to wordpress’ own primary filter function?
Hello !
Please try and add a flex block and in its filtering settings add only the breastfeeding category: https://www.screencast.com/t/3pUaa4Nmk Select only the breastfeeding category.
Let us know the result.
Hi Vlad,
Not sure if it was the update or not but I changed the settings on the extra section as marked below to 2 and it seemed to let it load then ok.
https://imgur.com/a/GLKWRHa
Can you help me with the social counter not displaying the Instagram icon even though I have it filled in on the header section?
Actually just noticed it has deleted the username itself since I added the Instagram username???
sorted… won’t accept a copy and paste of text so entered the text manually
  • This reply was modified 6 years by tbk1974.
