infinite loading or infinite loading+load more does not run on the category pages but standart pagination is working 🙁
WP General Setting Read Setting Max post: 10
bkz: http://mecburlar.com/kategori/haber/
NORMAL PAGINATION
INFINITE or INFINITE + LOAD MORE
@Mecburlar i’ve try with the big grid enable on category page, and the pagination work again !!
It’s a problem for me, because i don’t neeed & dont’want this big grid.
Friendship, Yann.
Hello Mecburlar,
Please re-update the theme with the latest version. (6.6.2) The problem with category pagination (infinitive loading+load more) was an issue caused by latest the update of WordPres and this was solved in the same version after solving with standard category pagination. Please get again the new version from Themeforest and install again and the pagination will work perfectly.
Sorry for the inconvenience!
Thank you for the message!
The problem was fixed in the current version of the theme released on December 15: http://screencast.com/t/ZJ1DRGi9Wnu. So if you downloaded the version yesterday you may have downloaded the previous version as this was just a fix we added to it (the theme version was not changed for a simple fix). Please download the theme again from envato and replace the files with the ones freshly downloaded.
I have checked your website again and the pagination on categories works fine:
page 1: http://screencast.com/t/O3ccKfg8ofx
page 2: http://screencast.com/t/FWTOjLvIc
Bogdan B. Please read the my first message.
Normal paging already working. I know 🙂 I say “infinite loading or infinite loading + load more” does not work!
I understand that?
Mecburlar.
Please try to clear your cache and purge CDN files. This error was fixed in the current version and tested accordingly. If you still have the issue after update, and clear cache and purge cdn, then please send an email at contact@tagdiv.com and provide wp-admin and ftp access so we can inspect the issue and we will come back to you as soon as possible.
The style.css will only change the theme version number. The actual fix is in td_page_generator.php, tagdiv_theme.js and tagdiv_theme.min.js
If you replace your files with these new ones from the latest update, it should work if other modifications do not interfere with the code.
Basically you can keep your style.css and replace all other files and it should work.
Make sure you do a back-up beforehand.
Hi bogan, thanks for your quick response.
I replaced those files but still not working.
Do I need to change something else? This is a category in my site: http://ge2k.com/category/tecnologia/
Thank you again.
Please make sure you download the latest files from envato. There was another fix in 15 Dec (even if the version is still 6.6.2 there were 2 revisions to this version) so make sure you install the latest files. The fix was tested and it works as expected.
Please try to replace the wp-booster functions file as well and see how it goes: http://screencast.com/t/SPR1FH8W70L
I have checked your website and saw you do not have any pagination on your categories. The problem fixed by the update was related to pagination. You have no pagination in the category so i cannot see the problem. Please describe the problem you have as it could be something else.
But I do have pagination enabled. Works only on normal pagination, not in infinite loading or infinite loading+load more.
For example in http://ge2k.com/category/tecnologia/ I have 6 more articles than never show up.
Infinite loading is working fine in http://ge2k.com/archivo/
Is there a minimun of articles to display?
Thanks again!
