1. When a user clicks the main menu (main category) on the main page, I want to make the posts in each category (including sub-categories) exposed on a single page.
2. For example, the main menu A (main category) has subcategories a, b, c, and d. When the user clicks A, I want to show posts registered in category A as well as posts in all subcategories a, b, c, and d on one page.
3. Currently, we set the [Popular(last 7 day)] filter using [Big Grid Flex 1] at the top (4 columns). Below that, the [Latest] filter is set using [Flex Block 1].
4. We applied the same settings mentioned in step 3 above to the page showing each post for every main menu.
5. We set [Category Filter] of [Big Grid Flex 1] and [Flex Block 1] to A on the page displayed when we click the menu (category) called A. By the way, when we click the B, C, D, E, F menu, all categories of the page displayed are set to A.
6. We want A menu page = A category, B menu page = B category… Is there any way to set this up? Please help us.
Hello !
You can create a menu and use custom links to your categories. Also if you are using only one category template this will not work. You will have to use a category template for each category and set it in here: https://www.screencast.com/t/nT9CHHnzDi
6. Do you want to have each category page with its own menu ?
