Even after changing the CATEGORY TEMPLATE, CATEGORY TOP POSTS STYLE and CATEGORY TOP POSTS GRID STYLE
no changes takes place on my website. Kindly check and revert what is the issue.
Please check after making the changes in the theme panel, if the modifications are saved. Refresh the theme panel and see if the settings are remembered. Every customization should be displayed on the website after saving. These are the all the category settings
– https://forum.tagdiv.com/how-category-settings-work/
Take a look at the theme system status and make modifications to these parameters if needed
You could ask your hosting to make them for you if needed. Then try again to save your settings in the theme panel, check if it works properly. Also clear any caching installed.
Let us know if there still is a problem.
