i have Newsmag theme v2.2 with updated wordpress site : http://www.koimoi.com/
however i am facing an unorthodox issue that in the theme panel in per category settings if i select
CATEGORY TOP POSTS STYLE : Grid 1 – Grid 2 http://www.screencast.com/t/gCqG1sigGRku my top posts appears on web as per the settings applied. (http://www.koimoi.com/category/bollywood-news/)
however those top posts are not visible in the mobile device http://www.screencast.com/t/8LFpRKYh4Io
and this goes with all my category .
if i disable the top posts grid style then pagination stops works i.e. same posts repeats it self .
i have asked the same question here too (https://forum.tagdiv.com/topic/category-page-repeating-the-posts)
That issue occurred after WordPress released V 4.4.1. but in last theme update we fix it. You can use theme’s path and update only the modified files. I’ve noticed that you’re using V 2.2 of the theme. In this case you need to go trough every path from 2.2 until 2.3.5 and update the modified files.
Before making any changes make sure you do a full backup to the current wp install and also the database. This is a security measure, in case something goes wrong you can always get back to the previous install.
