Cathegories, same display everywhere
Good day,
I have the problem that in all categories above everywhere the same 4 articles are displayed.
What can I do to change this?
https://e-m-l.ch/category/kategorien/
https://e-m-l.ch/category/ausbildung/
https://e-m-l.ch/category/umweltschutz/
https://e-m-l.ch/category/energie/
Regards Raphael Gasser
For the category template, if you have set a posts loop then will display all posts in this category or you can use Flex Block/Big Grid Flex and set the filter to “Category -Current category” => https://i.imgur.com/7P99qx0.png and this is why the block will display posts for each category. So, pleased check the settings.
