We have a CDN running and the images are not stored on our server. For this reason it displays the following WARNING, how can we solve it?
[20-Jul-2020 08:59:44] WARNING: [pool DOMAIN.com.br] child 44607 said into stderr: “NOTICE: PHP message: PHP Warning: getimagesize(https://CDN.site/2019/10/Logo_SCD_Prancheta-1.png): failed to open stream: operation failed in /home2/DOMAIN.com.br/httpdocs/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 792”
Thanks,
I think that this problem can be solve by adding an extra parameter in a theme file, the file path is wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 792 set before getimagesize and ‘@’ like this -> https://i.imgur.com/VOWmTCI.png
Also make sure that allow_url_fopen = On;
-> https://chemicloud.com/kb/article/how-to-enable-or-disable-allow_url_fopen-in-cpanel/
-> https://www.a2hosting.com/kb/developer-corner/php/using-php.ini-directives/php-allow-url-fopen-directive
We had a similar issue, and it does look like many people continue to post with the PHP Warning: getimagesize error on these forums. Support also told us to apply the same “fix”, however, this isn’t really a fix as it is just a bandaid. Each time the theme/plugin gets updated, we need to re-apply the suppression for the error.
Will this error ever be resolved in the main theme?
