Change Categories, Upper Right Corner of Blocks
Hello, I can not find where I can change the categories showed on every block’s upper right corner.
I attach an image:
https://s12.postimg.org/5rkt5pgxp/Captura_de_pantalla_2016_10_19_a_las_11_55_40.png
Thank you for your help
Hello Felipe Silva,
Here is talking about Ajax Filter option which can be modified from block settings. For more information about this, please consult our documentation here -> https://forum.tagdiv.com/newsmag-block-settings-tutorial/
Hope this helps!
Hello, thank you for your answer!
I have solved the issue.
Warm regards
