I’d like links in posts to be blue, however when I change this in the theme settings it changes the color of the Block Header 1 too. I’d like BH1 to be black. How can I achieve this?
Thanks,
Matt
http://www.matjoez.com
Unfortunately there is no separate settings for hyperlink colors in our theme. There is only the general accent color which handles multiple elements at the same time.
If you want to only change hyperlinks inside your posts, please check this topic:
https://forum.tagdiv.com/topic/hyperlinks/
