change color in related posts and next article
How can i change color in related post and next and previous article?
You can change the color like this https://i.imgur.com/9oJ3HGB.png please edit with tagDiv Composer the Single Post Template and select the template.
Sorry could you explain step by step how i edit it?
I think i have to edit color of td.block?
Was seeing now and i also need to change color of comments too
https://maisforex.com/index.php/2022/08/12/entrada-gbpusd-12-08-2022/
Im using style post 6
You can change the color with custom css
.td-post-next-prev-content a{
color:red;
Add this CSS code in Newspaper -> Theme panel -> Custom code -> Custom CSS
