Change fonts of AMP posts and pages
The AMP version of the website does not follow the theme fonts that I have set. Post content font size is too small to read. I want to change font size and font family of AMP pages.
Please resolve.
Unfortunately, the theme does not have any such an option for AMP custom fonts, sorry! If you want to add custom fonts for your AMP, you need to check the following topic from here -> https://forum.tagdiv.com/topic/change-font-of-mobile-theme/ where was discussed this case and follow the steps from the official documentation.
Hope this helps!
This link is 404
How do we change the font for mobile theme?
Try again because the link is correct and should works!
It will require to load the font first, then apply it with CSS for the elements you want. This is a similar topic – https://forum.tagdiv.com/topic/change-mobile-theme-font/
More useful information here – https://developers.google.com/fonts/docs/getting_started
So load the font first, then identify the elements where you want to apply it with the browser inspector for example
https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
